Trouble Wrapping my head around 3P4T wiring
nate433
I'm wanting to be able to quickly swap between 4 transistors when auditioning GE ones. I believe a 3P4T is what I'd want.
Going off of this diagram. Let's say A = Emitter, B = Base, and C = Collector. The 4 transistors would be wired up like this, correct?
E: 1
B: 5
C: 9
E: 2
B: 6
C: 9
E: 3
B: 7
C: 11
E: 4
B: 8
C: 12
I didn’t take the time to think about it yet, but moonn has a breakout for a 4 way transistor switcher using a 2p4t, so that switch should work too
You only need to switch out the base and emitter in this case, so yeah a 2p4t will work fine here. That's a neat breakout board.
