gregsmakercorner
Hi, first post here, this is my third pedal PCB. My first two were Blue Breaker and they worked great first try on power up! I was on a roll..
I have been troubleshooting all evening, checking my soldering, and going down the rabbit hole of checking all components (eg. Pots, resistors, etc). I'm really stumped on this one. I did decide to use LED's (red ones), since they are optional (vs. using the IN4148 diodes).
Here is the issue: the volume and tone pots work as expected. The drive pot doesn't seem to have any effect when I turn it. I confirmed using a multimeter that the A500k pot is operating as expected, and double checked all my soldering- no solder bridges, no cold joints, for the most part an appropriate level of solder everywhere.. I have a lot of soldering experience (other hobbies) but I was also going a little faster on this one, but after careful examination I don't think there is anything that looks off.
The only component I am really suspicious of is the 4558 Op Amp IC. I purchased from Amazon and they all came loose in a box. I haven't gone through thorough testing of it yet.
EDIT: Also.. the first picture does show that the tone knob isn't fully soldered in- I have already fixed that, but just used that same picture. The later 3 pictures are up to date.
Appreciate any ideas/thoughts!!
