mzy12
Hello!
I've been trying on and off over the past year or so to really try and nail this concept down and it has kind of driven me insane![Face with tears of joy :joy: 😂](https://cdn.jsdelivr.net/joypixels/assets/7.0/png/unicode/64/1f602.png)
I'm looking for reliable information regarding how you should calculate the input impedance of a guitar pedal circuit and more specifically, whether or not a pull down resistor effects input impedance. I'm also looking for how you should change the input coupling cap's value to accommodate for any change in input impedance in order to get the desired high pass filtering effect for a given circuit.
I've seen numerous resources contradict each other in relation to the pulldown resistor affecting input impedance. For example AMZ over at http://www.muzique.com/news/pulldown-resistor-vs-input-impedance/ says that it does, kind of. If you look at aion fx's documentation for their klon clone, they say that their added pulldown resistor is 2M and R2 (their voltage divider for the opamp) is inceased to 2M in order to maintain the input impedance. PedalPCB's kliche also adds a pulldown resistor, this time at 1M and the R2 value remains unchanged from the original at 1M.
I have a couple of questions about this. One is, is the input impedance of the PedalPCB's klon clone half that of aion's? Surely aion or PedalPCB would have to change the value of C1, the first coupling cap, in order to maintain the same frequency response? Or am I misunderstanding the effect input impedance has on the highpass at the input stage?
Thanks in advance for any response and I hope I posted this thread under the right section in the forums.
