mdc
My 14 year old weller iron finally bit the dust the other night, which is a pretty good run for a $20 tool that I bought at radio shack.
I don't have a permanent work bench set up in my apartment, so a nice station isn't super convenient. After hearing some positive reviews on the forum about the TS100 I decided to try one of these newer USB-powered models out. The TS80P seems to be the latest iteration of the design, with a bit more power than the old TS80 and a bit slimmer than the TS100. Max temp is 400°F and it heats up in sub-10sec. The TS80P may not get to temp as quickly as the TS100, but 10sec is better than the 5min I'd usually wait after plugging in my old one, so here we are.
Anyway, it seems to work fine! It was about 5x the cost of my last soldering iron and though I'd be surprised if it lasts 1/5 as long as the last one did, it feels like a tool of decent quality and the stock fine-point tip seems well suited to PCB work. The buttons are a bit fussy, and you have to be a bit careful about it flipping over in your hand as you're likely to tap the buttons if the handle is upside down. The included USB-C cable is a bit too short to be particularly useful, so I'd suggest getting the iron only rather than the "package" and just buying a 12V USB-C charge base and whatever length cord you want.
Mostly, I find the size off-putting. It's very small!
