Tungsten Preamp - another weird D.I. thing
I understand. Question is if there is more headroom with 12V, or in other words, if you got more distortion with 9V?
That's what I assumed you meant, and my answer still stands. The input voltage is fed directly to the tube heater only, the plate voltage generated by the SMPS doesn't change, and that has much more impact on the tone than the heater voltage does.
@vigilante398 I have the Particle Accelerator as a kit from Musikding.de (very convenient), but have not built it yet. Yesterday I ordered three more PCBs directly at your website (Bathtub, Tungsten and Vampire Slayer). I am going through the build guides and I have two questions:
- Tungsten Preamp: What is this RADJ for, and why is it optional? It seems it is important for the voltage rating of C1, but what means this exactly?
- As far as I could see in the other build guides, there is always this 10uF elko at the end of the power supply. In the Tungsten it is named C9, in other builds it has other names (C6 e.g.). It is rated 250V in the BOMs. But: is this not to little rated? I thought, it should be at least 400V, since the overall voltage is 250V?
Thank you as always for your knowledge and help! I am happy to build these nice tube treasures!
RADJ goes in parallel with the other resistor to set the high voltage of the circuit. This is optional because the original preamp that Tungsten is based on runs with a voltage rail of about 240V, and if you leave off RADJ then your high voltage will be somewhere around 235V. If you put a 1kΩ resistor in for RADJ then you will get something around 340V, which is higher than the original but which I personally liked for this circuit.
A 250V rated filter cap for the high voltage is the minimum that I would use on a 235V rail, and it is not unreasonable as there should not be variance in the SMPS output like there would be in a transformer-based supply, but it would of course be a good idea to go higher if you have access to higher-rated parts as it is always good practice to over-spec filter capacitor voltage ratings. Obviously if you install RADJ for a higher voltage rail then you will need a higher rated capacitor here.
Thanks!
I think there is also a mistake in the BOM of the Tungsten: C1 is there two times. I guess the "second" C1 with the little stars should be this C9 in the schematic, which I meant before (10uF electrolytic).
I bought this kit from musik ding and got 3x log pots instead of the various needed. Screenshot 2026-05-31 at 22.32.11.png
I also cannot find where the SPDT and 500k trim pot go.
I just ordered my parts from Tayda and realized, that the BOM is missing some parts. For example, there are only 3 pots, but you need 6. On the board some pots are called "B's" (linear ones), but in the schematic they are Audio tapers. Also one switch is missing (Amp Phase). I guess, the SPDT called "Roll Off" is for Hi/Lo. And you are right, there is no use for a 500k trimpot on the XLR board. I don't know, if Klaus from Musikding is aware of this. The Tungsten is rather complex, so it would be helpful to correct the BOM.
I've e-mailed both Klaus at Musikding and C2C but have yet to hear anything. I'm sure Musikding is aware of it, as the BOM link on Musikding no longer works, the Tungsten docs still do however.
Hallo @all:
I built the Tungsten, but there is a small problem. I hear crackling and signal dropouts from the DI output when I turn the DI output control. I already replaced the potentiometer, but that didn't help; the problem persists. Initially, I had an issue where the NE555 was defective. I replaced it, and the Tungsten worked after that—albeit with the problem I described. Could the faulty NE555 have damaged something else that is causing this issue? Where else should I look? Thanks for your help.
Sorry for my English, I had to use google translator ...
Cheers ...
Is the 1/4" output crackly at all? Check it with the phase switch in both positions to make sure please.
If the 1/4" output is fine then try a different XLR cable, also check all solder connections in case any are bad.
If you could please provide some pictures of the front and back of all the PCB's someone might spot something you have missed, it is so much easier to look at a good quality photo because you can zoom in on all the components and solder joints.
still waiting on getting the correct parts for the pcb, no reply from musikding on that yet, I've had the nearly finished built PCB on a shelf for a month now.
