The Gator
So I built the Tweed man circuit. I soldered up a bunch of SMD mpf4393 jfets. 20 to be exact. I tested them all using the breadboarded circuit that Chuck recommended and then put the results in a spreadsheet so I could sort them easily. I decided to use five of them that were all very similar. Vp tested at 1.82 to 1.87 and Idss from 1.60 to 1.68 mA. Q1 and Q2 received an almost matched pair.
The circuit definitely sound "tweedish" and the eq is really responsive.
The switch is a bit confusing. In the up position it is awesome!!! In the down position it is quite muffled. Lower output I understand, but the loss of high end in addition makes it seem not all that useful in my opinion.
From looking at the circuit, it looks like it cuts the Q2 circuit out completely. I am probably going to investigate changing hat a bit to my ears.
So I am interested in who else has thought and opinions on this circuit. Who has tried different jfets of different values?
Eh la bas ma stated he tried some different jfets and ultimately came back to the 4393s.
Anybody do any interesting mods to this cool circuit?
Thank you as always
Gator
Thank you as always
Gator
