Is the volume about the same for each way that the effect is switched? Or is one of the sides louder than the other?
If it is otherwise working but the output volume is too low, you may have the wrong value part installed on your PCB. You should double check the values of your resistors and volume control pot.
anything more specific than that will require more info from you, plus detailed pictures of your PCB on both sides and the wiring to your jacks and footswitch.
