Twinface (with VIDEO)
jfk1063
Hi!
I'm really pleased with how this pedal turned out so I decided to make a demo-video for it.
For the germanium side I used NOS AC128 transistors and NOS resistors and capacitors. For the silicon side I used NOS BC183A transistors and regular new resistors and capacitors. The only thing I added was a bodycontrol which is a basscut. I think this a really nice addition making the fuzz more versatile.
Enjoy the video and please like&subscribe :) .
Where did you get the knobs from? I got somr from LMS but I my pots are about 2mm too short! LMS does say you need longer than normal pots for them.
I might have to counter sink the enclosure on the inside to get them to fit.
Did you use different pots or anything?
Hi!
very carefully!
Haha sorry, it's a 500k pot with a 2nf cap before the input.
very carefully!
I’m currently building one of these for a friend and Im new to this stuff, I’m interested in using that bass cut pot mod I was wondering how you wired that with the input and if you use the three pins on the pit
It's a blend between two input caps so input goes to the wiper aka lug 2, the caps connect to lugs 1 and 3 with one lead, respectively, and the other leads of the caps both connect to the base of Q1.
For less bass use a smaller cap than the stock 2u2.
I think I actually just did this, but there might be better ways like mentioned above.
Cheers
