cablebasher
Hey guys
Building an Uberfuzz (superfuzz clone) and getting power supply noise on the output EVEN when the pedal volume is fully down
I DONT hear if when pedal is NOT engaged
Power supply is fine with other pedals
I have changed the 10Uf power cap and the reverse diode but no different
I have also removed the PCB from the enclosure and tried it on a pedal tester to remove all the in / out / led and power wiring.
I have done a continuity test on the PCB traces to check that the cap and diode are in circuit and tested capacitance. Seems good
I have done a continuity test between ground and power and there is no short connection
I have tried a number of power supplys and a battery and no change
Any ideas?
Thanks in advance
Any ideas?
Thanks in advance
