like Yeah!
edit- The originally intended question should have been about how to wire the given breakout circuit to another circuit to invert it on the input, but only when the pedal is active... so it would remain true bypass. the related corrected image is here at post #13. Living and learning is the spice
TL;DR: til that jfet buffers are not jfet boosts, and also that @Robert is a great human being.
Hi. I've read that single fet boosts invert the input signal.. and a way to uninvert it is to just use a single fet buffer along with it.
so i saw the jfet buffer board and i got one along with the fumble board ..for science!
i read in the docs for the buffer that it's literally a raw buffer and power protection/filtering are to be addressed by the installer (me).
Is this an acceptable way to provide power to the buffer board and connect it to the circuit as an input inverter that can be switched out of circuit?
[images removed (they were bad anyway)]
