I could not find a single description of what this pedal does, nor any sound samples anywhere, at least not under the name Unison Double Tracker. So I decided to try it out anyway just to see. I built it with no modifications other than a much higher value resistor to tame the insanely bright blue LED I chose. It was my second time soldering a SMT device; I went really slow and it worked the first time. I still don't know what the two sweep knobs are doing but some excellent settings are possible and when they are both doing whatever it is they do, I get a non-cycling pitch bend chorus without that tedious up-and-down, up-and-down effect that gets on my nerves with a standard chorus. The pedal still produces a very nice, light pitch effect even when the miniswitch is in the off position and the first parameter knob is turned way up; the second knob doesn't seem to do anything in that mode.
Having now built it and played with the controls for a while, I think it does a good job of approximating the Abbey Road Automatic Double Tracking "ADT" system.
I can use it as a very distinct effect, especially with an overdrive or fuzz either before or after, but I am finding that it's most useful with the toggle in the up position and the other controls set to very mild settings. It just lifts the guitar up a bit and makes it feel like it's floating, but it's so subtle that it never gets old.
It's one of those things that I don't notice it all that much but I definitely miss it when it's off - everything seems flat and dead without it.
