MichaelW
Nothing fancy to show off, I've been building a couple of utility pedals this week.
First up:
An active ABY box with buffered outputs. My new amp has 2 inputs to two different preamps. One channel is a Fender 5E3 style input and the other is a Marshall SLP style. You can combine the two as well. So here's this was my solution, I used a GGG Dual IC buffer board.
Next up. I wanted to be able to switch between my desktop rig and my amp rig without having to swap a bunch of cables. So I built an active A/B box that sits at the end of my "front of amp" chain that lets me easily route whether the signal goes to the amp or directly into my Apollo. This one has buffered input as well as the outputs. I used the GGG single IC Buffer board.
I also used a crappy enclosure that I got got from LMS that I've been sitting on not wanting use because the powder coat is funky.
And lastly, I have another amp coming (hopefully today) to check out. It's a "D" style amp with a passive effects loop. So I built a little opamp buffered loop to function as a "stand in" to a Dumblator. If I wind up keeping the amp I may look into a tube driven efx loop. Again used the GGG IC Buffer board, those things are handy. (and again another crappy enclosure from LMS.) This one is buffered in and out and also buffered in the loop.
I ran out of TL071's so had to ginny up one of my SMD ones using the PedalPCB adapter boards.
First up:
