This is far from my first build, ive built plenty of pedals including 5 working ones from pedalpcb and a few amps over the years but im running into issues with this valhalla build and im unsure where to go.
It presents as a signal that cuts in and out both bypassed and active and after a bunch of debugging seems to be a power issue, the buffer and subsequent tl072's are not getting enough voltage.
Initially I assumed the LM78L12 I had was my issue even though the datasheet was essentially the same as L78L12 so I finally got some of the proper L78L12's today and plugged them in hoping that would resolve the issue, it did not.
I have the incomming 9v from the power source on pin 3 of the L78L12 (VIN), but pin 1 (VOUT) which connects to the charge pump is 7.3v. The +12 and -12 reference points above and below the tc1044scpa are also not 12v/-12v. r31 / c26 point is 7.3v and r29 / c24 seems way off, 110mv.
I ordered some tc1044scpa from a different source.. so maybe thats the issue but figured id make a post incase someone saw something or had any ideas.
Pics were to big so i threw them up on imgbb as well for higher res
any help would be greatly appreciated! All the others (tyrian, hyped fuzz, dirty sanchez, sanguine, etc) from pedalpcb worked perfectly but this one just refuses to cooperate!
