Hello, I'm new to the forum.
Built a couple of pedals before (a delay, a noise gate and a compressor. No issues there).
My knowledge on circuitry is not the best compared to the craziness I read around this forum, so bear with me.
I built a Valhalla Distortion and I'm getting the famous squeaking.
I went through every component, and found that all of them are correct and correctly placed on the board.
When using the POWER OUT, with the pedal off there is no sound, as expected. When I turn it on I get a big squeak that can be played around using the EQ and Gain knobs on the pedal. I can make the squeal go away by lowering everything. I can hear my guitar with distortion, but very muddy and far away.
When using the normal output, the bypass sound is perfect, no buzzes. When I turn the pedal on it goes into squeak and hum mode.
Funny fact, when I have it on, just touching the pots on the pedal or the ones on my guitar, and also touching the strings, changes the frequency of the noise. Also, when I throw a chord on the guitar, the squeak kind of goes away. It squeaks when the guitar is idle most of all.
I've read around threads, and saw a fix involving adding a buffer pedal before the valhalla. I don't have a boss pedal. Tried adding in a noise gate I got from Musikding, that pretty much clears the sound totally. Also saw people introducing a second board on the pedal itself, but the reason for that goes beyond my knowledge.
Can I get some help here please? How should I go about troubleshooting this?
Thanks!
Here's some pics of what I have. I use a 3d printed enclosure, and I removed everything from there except the DC input to take the pics. Happy to take more pictures of any detail you wish
Thanks!
