PKRPedals
I have noticed a couple quirky things with my Valhalla since building it. It has the same squeal/oscillation that my pineapple has when the gain is up around 2 oclock. Also when turning down the eq section all the way, it kills the volume. I run my cable from the power amp out to the front of the amp, it actually sounds better to me this way, and the pedal acts like a mute when you switch it off, but this my be normal for it to do that. Just thought I would bring it up. I have used all my guitars with this pedal and the pineapple and they all cause the squeal. I thought my Les Paul was different but turns out it does it to. These are the only 2 pedals that I have this issue with and I can't seem to figure it out. I reran my cables in the pineapple with shielded cables and that may have helped a bit, but it still has the squeal. My Thermionic and Thermionic Deluxe don't have the squeal. Now with all that said, these pedals sound amazing but I have to roll off my volume just a bit to make the squeal go away. I can deal with it but would rather it work properly. Any ideas?
