Built this one a few weeks ago. I've been working my way through some Jeorge Tripps/Way Huge classics. It has that gatey, spitty sound but it's a little less fuzz and a tad more distortion. Makes it a little more usable than other similar fuzzes. I easily fit this into a 'B' enclosure with side jacks. I would love to say everything else went easy but this one is more of a cautionary tale. I make so many pedals and I was looking for a way to go a little cheaper on pedals I know I'm not going to use regularly.
I bought a bunch of cheap parts off of Amazon and that was a HUGE mistake. The DC jacks were so bad I immediately returned them. The nuts wouldn't even fasten to the threads. I had a similar issue with the 3PDT switches but they fastened "enough" that I decided to keep them. Though I won't buy them again. The jacks are usable but a pain to solder. For some reason the sleeve tabs don't take the solder very well. Even after a little sanding. I won't buy them again either.
Lastly my beloved 3 dollar SBE enclosures have finally failed me. As I finally got everything boxed up I noticed the pots were at an angle when i went to put the knobs on. It took a few minutes but I finally realized that inside the enclosure there were circular flanges that were raised up more than I had noticed on other enclosures. That was what was causing the pots to sit crooked. So I had to try and sand them out enough by hand to a point where the pots would sit a little more flat in the enclosure.
It also took me two tries to figure out which way the transistor is suppose to be oriented. I initially went without a socket because it didn't really fit in one. After guessing wrong the first time I installed a socket and cut down the legs enough to push them into the socket. I wish after all that work this was a pedal I would use more but I guess the lessons learned will come in handy on future builds.
![IMG_1721.jpg IMG_1721.jpg](https://forum.pedalpcb.com/data/attachments/39/39799-d610f1e2ebea1f2b16d15ac11ee55dae.jpg)
![IMG_1719.jpg IMG_1719.jpg](https://forum.pedalpcb.com/data/attachments/39/39800-83c7c2ff86bd9adc9df1825ce43bc225.jpg)
![IMG_1718.jpg IMG_1718.jpg](https://forum.pedalpcb.com/data/attachments/39/39801-93b8ac2e5ff5dfeb0be27c280a0baa26.jpg)
