perfboarder
Have very subjective weird opinion.
Always choose perfboard, specially the thick perf like double sided chinese green board. Why?
+ Thick, of course. Hard to bend.
+ The pads is just right size, and hard to lifted.
+ Its easier to solder right angle pots, or if you hardcore faster, you can do solder from component side. Remember, its double side.
+ Art of perf is bend that leg and use as trace.
+ You can do veroboard style in perfboard, without cut the pads. But you must connect point to point. Its easy, just bend left or right.
+- Perf layout is easy convert to pcb, so its good start if want to move real pcb build. Although you cant always have vertical component like in beauty vero layout.
- If you put wrong component, more work to correct that.
Its back to preference, what make you comfort and fast to build.
