Fama
How do you set your pedal volume pots? Does anyone use the first ~third of the rotation? I think generally it's a preference that unity should be around middle (so 12 o'clock), but I find myself pretty much always using either unity, a bit more, or a lot more, depending on the pedal and use case in general. This means most of the pot range is not used.
Some pedals have unity around 9 o'clock or so, which means more of the range is useable, but those pedals usually go VERY loud too from my experience. So it's maybe less of a design choice? Not sure.
Does that bother anyone else, even a little bit? Does anyone use pedals set to much under unity? I know Mad Professor has an "Underdrive" pedal which is meant for when you run a distorted sound on an amp and want a pedal that drops the signal so you can get a clean tone.
Is this a stupid thing to focus on? (don't answer that)
