What’s on *YOUR* workbench?
Work and life are getting in the way of pedal building, but a couple weeks ago I mostly finalized my design for a faceplate for my DuoPhase build. Today I laser cut a prototype in clear acrylic (just because it’s cheap and easy to source) that I will use to test the fit on the pedal before I laser cut on the actual two tone acrylic (which is also thinner than the clear one). I also did a test on a thin sheet of plywood which may make for some interesting “rustic” designs.
Here’s my prototype:
I went with no knob markers because I thought the design would get a bit too crowded. I also tried to find a font that matches the original graphics. Oh and I swapped A and B because the order is right into left and thinking B into A was hurting my brain (the pitfalls of being an engineer). I had some more elaborate design at first with an outline of a comb filter but I chucked it because it looked too busy. This is plain and functional.
Edit: looking at it now I think I’m going to add some knob lines. Maybe just 7 lines…
That acrylic is sick. If you could side light it like a cheezy desktop sign it would look insane.
Thanks! Yeah it looks pretty good. I haven’t figured out a way to use it like that yet. Also it’s too thick: I wouldn’t be able to put the nuts back on pots and switches if I used it!
If you make all the relevant holes big enough to accommodate the nuts it can work. Love where you‘re going with this in any case!
(Moved from the other Workbench thread):
Just getting started in this hobby as I'd only built a couple of Aion FX kits to date and wanted to really dive in this winter. So I ordered a range of components from Mouser, Tayda, and Lovemyswitches, and a Red Herring PCB from Pedalpcb. Best of all, I decided to get the Pedalpcb protoyping board so I can breadboard pedals without all the hassle associated with loose offboard connections. I've watched more than a few Wampler vids and I like the way he does it.
I'm glad I got the prototyping board; after a few hours of soldering the many parts onto the master pcb, its now working (!) with a Clark Gainster / Hoochie Mama circuit on the breadboard. I'll be playing around with this for a while to understand the subtle differences between those pedals and the Menatone Red Snapper (which the Red Herring pcb is based on). Whatever I like best I will build using the the Red Herring pcb as a base.
