What’s on *YOUR* workbench?
Edit: yup. 16 conductors going to a 4P3T rotary switch. 12 conductors to a 4PDT mini toggle. Six conductors for two pots, and the normal power and in/out stuff.
39 all together. Sweating bullets with each conductor trying to keep it clean, neat, and not fuck it up. Wish me luck on this guy.
That’s the reason I have a shoebox of unfinished Vero projects haha.
For real! PCB mounted potentiometers have spoiled me. Back when I first started building everything was off-board GGG or tonepad offerings.
It's vexed me from the beginning. Melted insulation, snapped wires at the board. Sloppy looking builds because the wires are a little too short or a little too long.
Some of y'all have taught me some valuable lessons through your builds. Little bits and pieces that I've been able to adapt for my own uses. This thing is a monster, though. I just had to decide to use a greyhill sub-mini rotary switch too.
This horn-dog…
I bought a used carbon bike frame and posted it in the mailbox thread. I considered refinishing it since matte black is overdone.
I decided to polish it to a high gloss instead
Before:
After:
And she's alive! One Chinese, all carbon special with hydraulic brakes and electronic shifting! It stinks that it is so cold outside.
Nice!
We just each got a pair of Trek Farley 9.6, all carbon fat-tire bikes. These things easily allow passing over sloppy sand and snow up about 4 inches deep.
Those are some serious tires!
i have a couple bike shops near me that I will go to when I'm looking for a specialized bit to remove a freewheel or when I need a bike clamp. One is a Trek Store and the other is a local business. The local shop is unfortunately staffed by two guys that are complete snobs. The people at Trek are decent and never made fun of anything I brought in; not even my $239 Eurobike.
I'm not sure where I was going with this. Trek has great stuff but man are the prices eye watering. $14,000 for a Madone...woof.
Trek is so ubiquitous and broad-coverage that it's easy to find something you like. I'm not a fan of their highest- or lowest-end offerings but their midrange is super solid.
Bikes and parts have gotten super expensive, and further good luck to the poor sods (me) who live in Canada. I used to tell people that ~$5k is the point of diminishing returns for most enthusiasts, but I don't think that's true anymore. Local tech told me recently that "things have gotten to the point that a bike wearing Ultegra is $8k" which in retrospect seems unimaginable. I'm in more than $3k on a custom build plan that will carry 105, so I guess it's true.
Boxed up the Sandblaster fuzz, had some issues first with the jacks shorting out, but a quick rotate fixed that.
It works fine, what I'm curious about from others who have built it, how much of an effect did the buffer have for you? For me it gives a big boost to gain, which I do like, but from a quick look at a demo it doesn't seem accurate to the original. I wonder if I maybe have a cold solder joint somewhere or if it's because I used 2N2222A's for Q1 and Q4? I couldn't find BC182's easily. I'll test some more, check if wiggling the switch makes a difference and maybe try some other transistors (2N5089? I think I read someone suggest that somewhere).
I might also have different gain levels, not 100% sure, and of course that's tricky to check against demos because I don't know for sure how their amps are set up. But I do get a nice range of clean-to-fuzzy, although that's with the buffer switch set to the higher gain position (which one is on, btw? I think I can probably figure it out by measuring it, but if someone knows off-hand...).
