Ugh, gotta be honest with you man, I'm not liking the location of those cracks. I can't remember but was this a Warmoth neck?
Yeah, Warmoth. They seem very surface-level?Ugh, gotta be honest with you man, I'm not liking the location of those cracks. I can't remember but was this a Warmoth neck?
What bothers me is the proximity to the tuner holes. Pretty common place for Fender style headstock to crack. Usually when you're tapping in the tuner bushings. I'd take some close ups and send them to Warmoth.Yeah, Warmoth. They seem very surface-level?
technically on a bench now.Hopefully it all works when assembled…
Eventually (soon) I want to mount this permanently. This parts washer I was gifted about a decade ago is irreparable (by me), and I don't wrench intensely enough these days to necessitate one, so repurpose time. Planning on mounting through the pan, plywood on either side, maybe dampened with some linoleum scrap. Makes a perfect shavings catcher (at least in the test drilling I did last night.
Works great. Also helps having decent bits.
I like that and will probably steal the ideatechnically on a bench now.
I have my people do that, of course. But if they don't I wont know or care, because they're in a different city anyway!You guys clean up after drilling?
I have a shop vac next to the grizzly drill press. I cleanup just to keep the dogs from testing to see if it's edible..... Especially if I've been drilling G10 for a circuit board. I use a fan behind and slightly to the side me to blow the toxic fumes away, AND I wear a acid vapor approved mask. Nasty nasty stuff....You guys clean up after drilling?
Oww. What's stuck in my toe?
It just now occurred to me that I might want to thoroughly clean out the dregs of that washer, since it's likely a concentration of rust particles…
I don't think my homeowners policy covers thermite disasters.
now I want to play Dark Forces... Except for the phrik mining planet level. Cool fog effect, wretched level. Those freakin phase-1 dark troopers (Terminator T-800s via MK II Baraka) will h*ck up your day quicker than almost anything apart from those kell dragons Jabba kept as pets.Twas my favourite weapon playing Dark Forces.
