Ok Gang, I call upon your expertise and good graces. Building a headphone amp with an acetylene preamp into a ggg MXR headphone amp board. Acetylene works as advertised, but the amp just ain’t amping. I have checked values, reflowed joints, checked for solder bridges, and yes, even audio probed the SOB. Findings thus far is that the signal is dead at pin 6. Swapped ICs with same result. Voltage readings look to be off. With an 8.99v source, I have 8.3 at pin 3 input. Quick calculation using Vout= Vs x r2/(r1+r2) says it should be more like 4.45 coming from between r12 and r13. Unless I’m being a complete dumbass and that’s not a voltage divider. Here are the pics:
Hopefully one of you eagle eyed/technically savvy persons can help me out here
