Wonder Drive
Mourguitars
Long time Guys !
I have another Wonder Drive PCB to build and was wondering if i could make that Tight control a little more responsive ....more tight
Chuck B ?......Anyone..
Thanks for looking and everyone stay safe !
Mike
  • Like
Reactions: fig
So...before i put this info in my notes...if you want to increase bass or treble you lower the value , them up the value if you want to take out ...correct ?
Mike
No.
Generally speaking, a larger cap lets more bass through, the smaller the cap value the more treble (ie it's blocking bass), but you also need to consider what's surrounding it, ie how it's being used.
It also depends on how the cap is implemented into the circuit, though.
If you want more bass in your circuit, a common way to do it is to increase the input cap value. Doing so might overload the circuit (which may or may not be desirable). If the circuit is undesirably overloaded with bass, you could decrease the input cap, and to compensate for choking off the bass, then increase the output cap's value. Some circuits boost the highs at the beginning of a circuit, then reduce them at the end — all in the name of reducing noise/artefacts.
If you plug in some values here: http://www.muzique.com/schem/filter.htm
... you'll get an idea of the corner frequency thingermabobbie.
If C1 & R1 above are .047uF and 4700Ω (47n/4k7), then the corner frequency is 720.8Hz (Tube Screamer's corner) and bass will be reduced below that corner and pass on the highs above it.
Reverse the positions as in R2 & C2, retaining values 4k7/47n respectively, the corner frequency hasn't changed, but instead C2 is dumping highs to ground and bass freqs are being passed along to the output.
A pF bleed cap on a pot, for example is going to let some treble bleed through. Increase the value and you're letting more "bass" through, but really letting more signal through in general and because the pF value is so small the "bass" that you're letting through is actually still well in the treble range — so effectively you're just letting more treble through, ie a wider band of treble.
To reiterate: increase a cap value for more bass, decrease for more treble.
Thank you for the very detailed reply Feral Feline !...again thanks !
At 59 im having a hard time learning to read schematics for some reason ....i know a lot more than i did when i first started but still do a lot of head scratching....i dont mind asking questions tho, and will...lol....., i watch guys like Jason at Headfirst amps doing his mods...explaining things in great detail from the schematics on his amp mods
I can change parts at least and dont mind being that one guy who all ways raises his hand to only answer the question wrong....one day this will click...i have faith !
Thanks again and ill print out your reply and put that in my notes !
Mike
You're not that much older than me!
It's taken me a few years to wrap my grey matter around this stuff, and there are so many here on the forum that are light-years ahead in their knowledge and understanding — I'm still scratching my head and asking questions on very basic stuff. A good way to test if you understand something is to try to teach it to one of your peers.
I keep working on reading schematics, it's really helped — more than that, it's given greater satisfaction and enjoyment to the hobby. The most recent thing I just picked up was chassis-ground. There are many ways to scratch out a ground symbol and I figured it was a matter of style/preference; but I just learned from my amp sifu the difference between a common-ground and chassis-ground symbol.
Q: Can you guess which is chassis ground?
A: No 5020
Apparently not everyone is in agreement...
I'll go with my very knowledgeable mentor's version of chassis ground, ie the "trident".
What grounds are there for having so many different symbols?
Some more reading up for me to do.
I'll stop learning when I'm dead. Maybe.
A: No 5020
Ok .....lol.....this kinda thru me for a loop ! But good stuff !
Im used to seeing the ..well what i called common ground (earth ground ) ive heard that term before, always thought ground wire always goes to the chassie...and was the same symbol
I just looked at my schematics for the Rocktron Valvesonic Plexi ....i see those chassis grounds now !
They have a note that the symbols are PCB_GND .... TP_GND .... CH_GND
On my Ceriatone 800 schematic all ground symbols are next to a screw/nut that is grounded to the chassis ...earth ground and not Common like i called it before
When i get a chance , i will take the top off the pre amp and take a chop stick and trace and see what that TP_GND is ...i see quite a few in the schematic
Good stuff Feral Feline !
Learned something today !
Mike
Comparing the circuit to two savage drives (my friends and mine) these are some tweaks to make it very similar to the actual savage drive. main ones for more tight would be R15 & C7
R4 - 220r (I used a trimmit with a 100r 1/8w resistor in series with a 500r timpot)
R8 - 100r
R9 - 15K
R15- 470r
R19 - 4.7K
C7 - 2.2nF
C10 - 100n on some gut shots and my friends v3, 150 on others controls the top end sharpness (I put on a on-off-on dpdt switch with 56nf 100nf & 120nf caps)
R8 - 100r
R9 - 15K
R15- 470r
R19 - 4.7K
C7 - 2.2nF
I found a rev 2 PCB that i have ....has anyone done these changes above on that board ?
Also BigK do you have a gut shot you can post ?
Mike
I know I'm late to the party and all, but...
C7 determines how much bass gets thru when TIGHT is full CW (maximum tightness).
C1 determines how much bass gets thru when TIGHT is full CCW (maximum fatness).
If you want it to go tighter, make C7 smaller.
If you want it to go fatter, make C1 bigger.
Note: you can do both. They interact a bit, so dial-in one cap, then the other. Then repeat.
The effect of the TIGHT control is more pronounced at higher DIRT settings. When DIRT is at zero, the TIGHT control does almost nothing.
Thanks for the info Chuck !
I usually have the Dirt about 10 am ...well i set pretty much all my OD's that way , looks like we have some bad weather coming via a few storms so that will give me some free time to build...!!!!
Mike
I can't attach pictures for some reason.. (if you do a google image search there is a few) but I've built two like this for friends with the 3 way bright switch but in the centre (100nf cap) it sounded identical to my Airis savage drive - so much I sold that and have another Wonder drive board to build up for myself with my tweaks as I like the ability to to change the bright caps and play with the frequency of the Tone/bite knob to dial it into my different amps.
The other thing is that Airis put over the top amounts of gain into the circuit to R15 on the board for the wonder drive was actually a 47r on my friends portal drive (savage drive with rick and morty graphics) but when I used that it often caused some oscillation with different opamps so increasing it to 470 lowered it enough to remove that.
Incidentally my VFE ice scream turned me onto the trim for the tone frequency and I put it on all my OD builds. Another pedal worth building its adjustable mid boost is brilliant.
worked this time
worked this time
Cool and thanks for the pics BigK !
I figured work would most likely slow down some but instead it speed up like a rocket...the Fishing tackle biz is crazy , people cant get anything but i work on getting stuff in...i kinda created my own monster with me being Pro active working late nights....all i want to do is relax and build a pedal or two....lol
Mike
Pulled some of my parts, need to print out the build docs...trying to decide Blue or Purple for the enclosure...its nice having all the parts for a build here for once...Saturdays project !
Hope it goes smooth.....Lol
Mike
Hi there! Good evening, what can I modify to get a little more volume? I'm also going to play around with the C7 and R15 values a bit to see how it sounds. Greetings and thanks in advance!
Ariel.
I'm going to check it just in case, with all the controls at 12 o'clock and the volume at maximum there is no difference between the volume when the effect is turned on and when it is turned off, it is just the volume, the rest of the controls work fine.
With those settings, the gain should be around 20dB (10x). Try it with DIRT at max and TIGHT at zero. This thing does not have a lot of gain, but it should be louder than what you describe. You might want to verify all of the resistors and caps are the right value.
Anyone else with a Wonder Drive want to chime in?
