Woodpecker Tremolo Buzz Issue
JRobb310
Wondering if anyone has had an issue with the Woodpecker having a buzz? It doesn’t buzz until harder picking. Power supp/chain? It was working fine in the beginning but once moved it started it. Any ideas?
I have not built the Woodpecker, but it's interesting that you mentioned it was working fine until it was moved. Did you happen to change power supplies? Did you socket any parts that may have wiggled loose? Or perhaps it could be a cold solder joint popped loose. Pictures are usually helpful for troubleshooting.
No change of power supplies. The only thing I can think of is possibly something popping loose but everything was solid so I’m not sure why it would. I’m going to open it back up and check it out.
