Worried I roasted this solder pad
Stevohuff
How bad is it? Ground/output on the low tide
If the pad is indeed damaged you can connect the wire to this pad at the footswitch instead.
Connect the GND wire to any other ground point in the pedal... (the other GND pad or 1/4" jack, for example)
