I will … I plan to begin a project next week! Possibly a Big Muff ….
For sure!
Don't worry about cranking up your heat every now and then too. The temperature of your iron doesn't matter as much as the absolute quantity of heat transferred over time.
To illustrate what I mean...it's important to know two terms...I'm gonna use the imperial system cause that's what I know...
Specific heat: the amount of BTUs required to raise the temperature of one pound of a specific substance 1 degree Fahrenheit. (Water is the baseline; 1 btu will increase temperature of 1 pound of water 1 degree Fahrenheit)
Latent (or "hidden") heat: the amount of BTUs required to cause a state change (solid to liquid, liquid to vapor) of one pound of a specific substance (Using the same example as before: water has a latent heat of vaporization of 970 BTUs, which means that it takes 970 BTUs to cause a pound of liquid water at it's boiling point of 212⁰F to boil into a vapor).
So...the same concept applies to solder. 60/40 solder has a specific heat of about 0.04 BTU/lb, where as it's latent heat of fusion is about 15.9BTU/lb.
In a normal soldering process, the goal is to elevate the temperature of the solid solder to it's melting point, add enough heat to cause that change of state from solid to liquid, and then slightly superheat the liquid solder beyond it's melting point in order to give yourself time to allow the solder to flow and make a good joint.
So, just by seeing the difference in 60/40's specific heat and latent heat of fusion (0.04/lb and 15.9btu/lb, respectively) it's easy to see that the actual melting of the solder is where your iron is doing the majority of the work.
If you find that you're having trouble getting the solder to remain molten, the solder is losing heat faster than your iron is able to deliver heat to the joint.
Yup...the name of the game here is heat transfer. Knowing that conduction between two materials is a game of surface area and delta temperature, there are two ways in which one can improve heat transfer: increase the temperature delta, or increase the surface area in contact.
Once the solder is molten and you can dip the circumference of your solder tip into the solder blob, the style of tip matters a little less, as the entire circumference is involved in the heat transfer process.
But...getting that process started is the trick. That's why I like using chisel tips, because they have a nice flat edge to em that you can use against the wire lead/PCB.
Happy soldering!
