Potentiometer Requests
StompBoxParts
Authorized Vendor
Getting a new batch of Cusack/STOMP pots made soon. What are you looking for that's hard to track down? Specify value, size (9mm or 16mm), terminals (short pcb leg, solder lug, etc), dual-gang if applicable, etc
Here's what we already have: stompboxparts.com/potentiometers/
Feel free to make requests of any sorts. Note, if you are looking for a new style of pot altogether, I may or may not be able to provide as getting every value in a new style is quite the spacial and financial undertaking. Your request will not go un-noted, however.
Lead time is usually 2.5 to 4 months, so keep that in mind.....
Not a pot, but how about the Hammond 1590STPC. I usually get them from Mouser, but they are pretty much the only think I order from there anymore. Not to hijack the thread or anything…
+1 on the 16mm W100K pots.
Also how about 16mm B100K pots with a center detent? not sure if that would count as a new style or not.
If the detented pots are a possibility, then 16mm B10k pots with 8 detents and with 6 detents would be super useful for various μP based projects— TapLFO/StompLFO; FV-1 and other DSP stuff, etc… That’s actually the same method Boss uses for the rotary selectors instead of true rotary switches in a lot of their products.
Hey there,
I've placed a few orders with you recently. I'm a total noob DIY pedal builder and just getting into the hobby with my first couple of builds. I've been ordering stuff like crazy from all over the place. Just wanted to say thank you and a shout out for your great website store and super fast turnaround I've gotten on my orders from you.
M-
Have you corresponded with Peter Rutter about possibly stocking some of the dual-gang dual-value pots he uses in some of his boards? I haven't seen any suggestion that he was going to stock them for his "branded" licensed pedals by DIY builders.
+1 on that^^^
+ 2 on compatible pots for VFE-builds.
I can get dual value gual-gangs. What values are you looking for, or what's the relevant project(s) I can take a look at?
Thanks for the suggestions, I'll be grabbing several of these requests.
Yes to clear shaft pots. I’ve had to order some from banzai and pay the shipping to US. If you find any knobs with illuminated ring, that would be awesome too. I’ve used some from duppa, but they are made for encoder type (no position indicator), so I had to paint my own dot.
Are 2-meg dual gang (linear, audio) possible?
2MC for legit EHX Hot Tubes Gain action 😬
I'll try out dual B2M to test the waters before carving out space for A and C. Thanks for the suggestions.
W-100k 16mm Short PCB Leg.
On the list. Thanks.
Unable to produce 6 or 8 detents at the moment. Looking into B10k and B100k center detents.
Clear shaft pots would be awesome too!
Looking into this. B10k, B100k?
Personally I have a project (eventual small production run) that would use clear shaft 50kA, 50kB, 100kB. Of course you don't have to plan around me... but I think in order for it to be useful for a range of users you'd want the basic values in log and lin.
Don’t have my computer or I could be more specific, but Madbean has a bunch of the VFE projects and there are a few on PedalPCB, too.
I’ll send you a PM when I get my HD back from the repair shop.
