Vtl5c9
Diynot
Yup, I did it, went to Madbean and bought the Wavelord. Ordered the taplfo chip from electricdruid. The final piece is the the vtl5c9. whose got a source or one to spare? @dawson?
Were I you, I'd order a couple each of 3 or 4 different vactrol types off of aliexpress, socket the pcb, and see what works best. You could also DIY with some LEDs and LDRs.
Wise decision on the Wavelord- unfortunately, I believe mine came from SmallBear while they were heading toward final hibernation.
Are you in the USA? I'll keep an eye out and let you know. I also wouldn't be surprised if somebody else finds one for you to buy in the next 30 minutes- folks can be good like that around here.
@dawson Thanks! I am stateside. I do have a couple of the NSL32SR3 from my MiniMu build that the build doc says will work, just not as well. Going to do what @mdc suggested and socket until some VTLs come available. Excited ab multiple waveforms!
@fig since you are the resident guardian of the unobtainium, you wouldn’t happen to have a Vtl5c9 in your stash that I might procure from you in return for monetary remuneration?
I have you one. I'll have to locate it. :oops:
A few months back I ordered a bunch of vactrols from various makers, as well as a decent sampling of the PerkinElmer brand, which seem popular in pedal designs. My goal was to learn all I could about them, what specific characteristics and specs are important, run some comparisons, measure & chart results....and of course build some groovy pedals. I've done some study, but hit/miss between life, building pedals, and running my fingers through the forum.
Here's the PerkinElmer spec-sheet in case there is an interest.
@fig It is pretty interesting the variance in properties of each vactrol, all dependent on the LDR construction and LED wavelength. I need to do a little deep dive on how an LDR is constructed and what factors determine said characteristics. Purely educational, but nothing wrong with that. I did consider grabbing some vactrols on my last SB order, but alas, I did not have a particular project in mind so I decided against it. Excited for this one though and glad Dawson brought it to my attention. Waveforms make me giddy
783C38B6-6789-405E-A419-C41605102866.jpeg so looking at the spec sheet above, doing a little research, and a little math, is it possible to sub a 5c1, which has the closest specs with the exception of a broader slope and faster response time, for the 5c9 IF you were to change r24 to 500ohm so that the input current is then 10mA, or am I butchering any and all math/EE norms?
I've found 5C1s, 5C4/2s, 5C4s, 5C3s, 5C3/2s...still looking for the 9s and 10s. I think I know where I stuck 'em. (y)
It's a great question...I just don't have the answer. 😁
I do know the specs of those 2 seem very close. I'm just beginning my edumcation on these kajiggers, but have pestered @Chuck D. Bones sufficiently to attempt a translation from electronic-speak to monkey-sounds, that I might grasp enough to achieve some meaningful results. I am forever grateful and open to guidance or correction. Oh, and I do like me some nana.
I feel ya
I have a few vtl5c9. Can't remember where I got them but my Wavelord sounds great. Just DM me. I'd use a socket just to be sure.
  • Love
