Nostradoomus
No worries, I have some time coming up, I’ll breadboard it again.
Do you have a MPSA18 handy for Q1, curious if that makes it jump out of the MixI’ll think about it...but this thing was pretty difficult to cram in there. I had a few 1590B’s laying around, and wanted to make use of them. I didn’t consider the depth, and getting the pots and the jacks in were rough...
See what happens if you lift R4- 22k from going to Ground ????I just built this today and honestly I haven’t had much time to play it but I did notice that I have to crank it to get barely close to unity gain. Maybe it’s just the nature of the beast? I used 3904 from Tayda.
You could try increasing the Input cap C1 from 47nF to 68nf or 82nF ???Well, 1.5 years later, and now I do have an MPSA18 handy. Just popped it in. Not too sure of the difference. It doesn’t seem any louder. Sounds good though. I’m not entirely sure that the pedal is quiet…maybe it’s the thinness of the tone making it seem quieter, less-meaty…
I'm curious what lifting R4- 22K to Ground will do, I'm suspecting a Volume increase????I wonder if a feedback resistor, say 100-200K from emitter to ground would increase the gain (it should provide 13dB at 100K)?
Ah right I forgot about that. I doubt it would change the volume because it’s just in parallel with Q2’s collector, which is the output voltage. I think it would just affect the frequency response?I'm curious what lifting R4- 22K to Ground will do, I'm suspecting a Volume increase????
I had the oshpark of that once and I think I re-gifted it during a madbean PIF.I build this version of the fuzzrite that has an integrated boost, body control, and Hi-cut option. Unity volume is at 9 o'clock on this one.Tequila_Buzz_1.1.pdf
drive.google.com
I just finished a Fuzzrite (on tagboard) and I put the 22k resistor on a switch. If I turn it off I get a ton more bass, presence and volume and the fuzz loses its trademark splatty character. Definitely happy to have the option.Ah right I forgot about that. I doubt it would change the volume because it’s just in parallel with Q2’s collector, which is the output voltage. I think it would just affect the frequency response?
I think the gain increases cw in the stock build?I just finished a Fuzzrite (on tagboard) and I put the 22k resistor on a switch. If I turn it off I get a ton more bass, presence and volume and the fuzz loses its trademark splatty character. Definitely happy to have the option.
My pedal is super loud but the volume depends on where the Depth knob is. As I blend in the second gain stage it gets much louder (BTW I flipped the pot so the gain increases clockwise).
I'll post a build report with some sound clips soon, hopefully.
In the schematics, lug 3 of the Depth knob goes to Q1 and lug 1 to Q2, so gain increases CCW. Several users have noticed this counterintuitive behavior. I don't know if the PCB has been revised.I think the gain increases cw in the stock build?
Edit: oh wait, mine is a PPCB build so that’s probably why.
Now you’re making me doubt myselfIn the schematics, lug 3 of the Depth knob goes to Q1 and lug 1 to Q2, so gain increases CCW. Several users have noticed this counterintuitive behavior. I don't know if the PCB has been revised.
BTW my build was ridiculously noisy until I boxed it up. Now, with all the grounds in place, it's only as noisy as your average Fuzz Face when everything is maxed out, with a bit of radio when the guitar is rolled off to zero. I read somewhere that a 2n2 cap from input to ground kills that noise but I just let my Strat on 2, it's still off but silent.The original (and the PPCB version) have more gain CCW. In that setting you have both transistors at 100%. As you go CW you are essentially blending Q2 out of the signal…
I think I may breadboard the 22k mod thing tomorrow morning (Summer semester prep can wait). If I like it it would be easy to mod…even with my build being in a 1590B. Thanks for the tip.
