jacobsteel
Hi there, I building a DuoPhase, sketching up a printable sticker (using Eurostile, but wider spaced) for the panel.
Font used on the Mu-Tron Bi-phase?
I guess Mu-Tron used something like the font "Eurostile" in the original design.
Here's a discussion on whether they used Microgramma or Eurostile. Still, you can approximate the Microgramma if you space the letters a bit wider.
However, I'm thinking of adding a few mods:
• Input selector (Pre A, Post A, B straight) for channel B is simple (but not yet drawn into the sketch below).
•An expression pedal would be cool, but cooler still would be to be able to use a common 200K volume pedal:
Question 1: has anyone added a circuit for that?
• Sine-Square wave LFO mod.
Question 2: Has anyone built a good sine-to-square-wave conversion?
• CV. I might add control voltage (CV), that's perhaps simpler than doing the Sine / Square mod. Or a toggle to external sync could be rectified and you'd have a crude envelope follower?
