DeuceOfAllTrades
I finished putting together the Brown Betty, and it won't power up (no LEDs, no output). I traced the entire power section using the schematics, which tested good for voltage. I get no voltage on the audio side when clipping the multimeter to ground. I've double-checked my wiring and confirmed continuity for all wires. This is my 6th or 7th project, and the first time I've run into problems. I'm not sure what to do next. Any suggestions? Even a link to another forum or walkthrough on this type of issue would be great.
-- Note, I removed the status LED when disassembling from the enclosure. I had a jumper in just to confirm voltages. I'm still confused as to how there is voltage across the status LED but it doesn't light up. I know my leads aren't trimmed well enough - I need new cutters as I can't get tight enough to the board. I've double-checked that none are bridged or contacting the pots.
