Saturday Poll: how often do you change your strings?
How often do you change your strings?
  • Once a month or more frequently
    Votes: 2 3.9%
  • Every 2-6 months
    Votes: 20 39.2%
  • 6-12 months
    Votes: 11 21.6%
  • When I remember
    Votes: 5 9.8%
  • Almost never
    Votes: 8 15.7%
  • Wait, you're supposed to change them?
    Votes: 5 9.8%
  • Total voters
    51
When there's only 3 left.
Last time I restrung my tele the prior strings actually unwound when I tried to tune up.
(I do keep one guitar with a full fresh set, though, which is about once every 8 months with stainless steel strings).
Bass, only changing to put flats on one P-bass. Otherwise, it could be awhile.
Guitars, hoo, its been a long time. But I haven't been playing them. Really need to, especially on the strat my kids bang on sometimes.
I generally like the sound of older strings, something about the new strings has a sort of twang I don't like. I just compensate with some more treble and call it good, so I change them when they break or when I want to try a different set usually.
Another write in vote.....
- When they need it.
I have so many guitars and some don't get played that much. Even the standard Ernie Ball Rock and Roll 10's nickel wounds I use stay in good shape in my air conditioned house. I use Elixir Phosphor Bronze on my acoustics, and it's the same, I change them when they need it.
Usually when the E and A strings start to sound dead. I play clean or low gain mostly and I kinda hate the sound of dead or dying strings. Having said that, because I tend to rotate what I play and general play a couple of guitars for a few weeks at a time, it might be 8 months to a year on some guitars and maybe 30 days on others.
Just to be clear, I love the Bigsby I just hate changing strings. And I won't buy that vibramate thing cause it ruins the look lol
I am up with Michael on this, I have enough that I just rotate to another guitar when the lower strings lose their sparkle, or I break the high-E.
My acoustic generally has 5 strings because I break the high-E and can't be bothered to replace it. It's a backyard guitar anyway..
My game changer was the String Stretcha. Saw a video with Steve Vai's guitar tech who recommended it, and I haven't looked back since. Took a large annoying part out of the string change process.
I used to work in a music shop and some of the strings were eye-wateringly expensive. Electric guitars strings are cheap! Try being a violinist in an orchestra. Or, as Mr Feline was implying (I think) an upright bass player. Some of the most expensive G-strings ever. Some of the pirastro gut strings wrapped in silver can be hundreds of dollars. My violinist friend hated having to change strings. For him changing strings was very much an "only when they break" thing. Not so much because it was a pain to change them, but because on a violin dead = good tone! New strings have annoying resonances to them - they're too lively. He said strings sound best just before they break. A bit like my voice...
When gigging I change my strings for each gig. In some bands where I played 3 sets it was a necessity, and I have quite gentle body chemistry. At home my strings can last for months. It's the dead wound strings I can't stand. I quite like changing strings and half of my guitars have Bigsbys. Once you get the knack for changing strings with a Bigsby it's actually very quick to restring them. The trick is to curl a little semi-circle in the end of the string where the ball-end is. I use a pen or even a jack plug to curl it around. Then it stays on the pin on the Bigsby relatively easily, especially if you maintain some tension on it with your hands while attaching it to the tuner. I hold the string up tight next to the tuner, measure around 1/2-3/4" of string past the tuner, put a kink in it there and then pull the string through the tuner until it hits the kink. That leaves you with just over one wrap around the tuner with the string which is all you need.
