chongmagic
I just purchased a Peak Atlas DCA55, I figured that I didn't need the PRO model and didn't want to spend the extra money. Is this just as good for measuring transistors or did I make a boo boo?
| DCA55 | DCA75 |
| General specifications: Test current (into short circuit): ±5mA (typical) Test voltage (into open circuit): ±5V (typical) Component Support
| General specifications: Test current (into short circuit): ±12mA (typical) Test voltage (into open circuit): ±12V (typical) Component Support
It looks like the DCA55 doesn't do JFET measurements (or Zener diodes), also the DCA75 has USB connectivity for plotting graphical transistor curves.
I will say though, I haven't been overly impressed with my DCA75's ability to measure zener voltage accurately... I find using a resistor, DMM, and power supply much more reliable.
DCA55 DCA75 General specifications:
Component Support
Measurements
- Bipolar transistors (NPN/PNP inc Silicon/Germanium)
- Darlington transistors (NPN/PNP)
- Enhancement mode MOSFETs (N-Ch and P-Ch)
- Depletion mode MOSFETs (N-Ch and P-Ch)
- Junction FETs (N-Ch and P-Ch). Only gate lead identified.
- Diodes and diode networks (2 and 3 lead types).
- LEDs and bi-colour LEDs (2 lead and 3 lead types).
- Low power sensitive Triacs and Thyristors (<5mA trigger and hold)
- Part type identification.
- Pinout identification.
- BJT current gain (hFE).
- BJT base emitter voltage (Vbe).
- BJT collector leakage current.
- MOSFET gate threshold voltage.
- Diode forward voltage drop (Vf).
Component Support
Measurements
- Junction FETs (N-Ch and P-Ch). Both symmetrical and asymmetrical types.
- Enhancement IGBTs (N-Ch and P-Ch).
- Zener diodes (up to about 9V).
- Voltage regulators (up to about 8V).
- Low power sensitive Triavs and Thyristors (<10mA trigger and hold)
- MOSFET on and off gate threshold voltages.
- MOSFET transconductance.
- JFET pinch-off voltage.
- JFET transconductance.
- JFET IDSS (drain current for Vgs=0)
- IGBT on and off gate threshold voltages.
- IGBT transconductance.
- Voltage regulator output voltage.
- Voltage regulator quiescent current consumption.
- Voltage regulstor drop-out voltage.
- Zener voltage.
- Diode forward voltage drop.
Yeah. The JFET measurements were a deal-breaker for me. I ended up getting the 75.
Yeah one of the main reasons I would want to have the tester.
Yeah same hereI wish I would have done the same thing. The DCA 55 is good for what it does and has helped a lot but I wish I had the extra features of the DCA 75.
Apparently neither of them are great at measuring germanium, but I don’t have one so that’s just hearsay.
Well hearsay will be null and void by tomorrow...ordered one![]()
Mine works good for germanium...I got the dca55 so we’ll see. I can’t justify twice the price for a few functions I can breadboard test.
