Electrovibe Mini...1) you can’t. Unless you put a 50k resistor in series but you still lose that much of a run on either end of the pot.
Edit: taking a step back, what circuit do you need it for? Maybe 200k could work, depending on the circuit.
The face coordinates can be used as listed. For the top (i.e., the I/O), the measurements are not taken from the center. I use these coordinates:..as for the AionFx Coordinates...
DRILL | Size | X | Y |
| Out | 9.725 | -15.875 | 7.5 |
| DC | 12.3 | 0 | 7.5 |
| In | 9.725 | 15.875 | 7.5 |
I saw the Aion template specifies closed jacks. I use open jacks. Of course, thinking of it now, I'm sure I can just use the measurements for the top that I used the last time I used the drill service...The face coordinates can be used as listed. For the top (i.e., the I/O), the measurements are not taken from the center. I use these coordinates:
DRILL Size X YOut 9.725 -15.875 7.5DC 12.3 0 7.5In 9.725 15.875 7.5
NOTE: This is for standard 2.1mm Boss-style DC jack and enclosed 1/4" audio jacks. Powdercoat adjustments are included.
In that case, you're probably fine using the PedalPCB coordinates. Here's the open-frame Aion template.I saw the Aion template specifies closed jacks. I use open jacks. Of course, thinking of it now, I'm sure I can just use the measurements for the top that I used the last time I used the drill service...
