Coda
You'll also catch hell for it in your troubleshooting threads.![]()
I stopped posting them right around the time white washer outrage peaked…
I soak in 99% iso and scrub with a toothbrush over a Kimwipe. Gets them nice and clean.
hahaha same here![]()
I have, I think I mentioned this in another thread a while back. I switched over to Kester "331" which is an organic water-soluble flux. It leaves a milky white film on the board after soldering and it turns out it's mildly conductive, so I had a bunch of weak shorts all over the board that caused problems. Never had it with "44" flux, which is non-conductive.Let's swing the question around the other way. Has anyone experienced failure from not cleaning the PCB?
I like the idea of an alcohol dip bath. But is that bad for any particular components?
Ok, I'll give the alcohol bath method a shot. But if I "bust a cap" I know who to blame. ;P (totally kidding of course)As long as there's no power (and everything is dry before you apply power) you'll be fine.
The folks who like to burn speed holes in to their caps might have a hard time with it, though.
I thought 99% IPA could melt poly caps. Also you *never* want ipa to get into pots or switchesAs long as there's no power (and everything is dry before you apply power) you'll be fine.
Good to know! I had always heard that ipa reacted with the binding agent used in the carbon track of pots, and that IPA getting into a pot would essentially melt it. Same deal with switches— I had heard that IPA caused crazing on the switches, and that over time the switch would degrade and mechanically fail.IPA in pots and switches is ok if it's clean IPA.
To be honest I actually completely agree with you. I can't stand the stuff. I'd much rather have a nice weissbier like Franziskaner or Erdinger.Still haven’t found a good IPA. I don’t understand the American obsession there..
So far the only thing I avoid (and have had problems with) soaking (swishing actually) in an IPA bath is potentiometers. Particularly trimpots. I think the dissolved flux gets into the wiper wafers and can mess them up. So when I do a board that has trimmers, I'll populate everything except the trimmers, then after cleaning I'll solder in the trimpots.For me, the best defense for cleaning a PCB starts with the flux used. I found no-clean flux like this to work really well:
Chip Quik CQ4300-2OZ No-Clean... https://www.amazon.com/dp/B093X9F9RN?ref=ppx_pop_mob_ap_share
I typically use some good plastic bristle brushes and good iso to clean them and use Kim towels to dry them.
Dogfish Head 90 Minute IPA is one of my goto favorites, although here in the US there are tons of small craft breweries that make some excellent IPA's. *Note that the 90 Minute is very different from the 60 Minute, one would think it would just be the alcohol content difference but the 60 Minute is kinda "meh" while the 90 Minute is fabulous, nice and malty and hoppy.Still haven’t found a good IPA. I don’t understand the American obsession there..
Can't hardly stand them, give me a Porter or a Stout, occasionally a good Brown AleStill haven’t found a good IPA. I don’t understand the American obsession there..
Ooh suits you sir. Good calloccasionally a good Brown Ale
SWISHING! not submerging....hahaha.....actually, I was somewhat leary of this at first too until reading @Chuck D. Bones's post.Honestly I'm shocked y'all are submerging your pcbs
