Germanium OCD
Then the "earliest OCDs" had the one germanium diode in series with one of the 2n7000s, so it's probably safe to assume the Germanium OCD did this twice.
You could do this with an ADHD board, solder a germanium diode to the two tied-together legs of the 2n7000 and put that into the right pads of Q2 and Q3.
I am building 2 of these and figure its worth messing around with tho see if it really makes a difference. Are you saying that connecting the ge diode from leg 1 to 3 of the 2n7000 will accomplish this?
There's a thread and some schematics on the germanium OCD at freestompboxes. I'm out at the minute but will have a look for the thread when I get home later
I would imagine that it’s using the Ge diode to block the body diode of the clipping MOSFET. Some iterations of the OCD don’t include a blocking diode and have the clipping arranged such that the body diode conducts before the gate junction of the MOSFET.
Some of the OCD schematics I've seen have a Ge diode in series with one of the MOSFETs, other schematics have no series diode. When there is a series diode, it's pointing the same direction as the body diode, therefore it's not blocking anything. I posted some MOSFET diode curves here.
You may be already aware of the following, but for the aid of those unfamiliar...
Some background info:
Applying the knowledge:
Diagram from the latter AMZ site above.
Those Ge diodes have a single green band, yes? That would make them Д9Ж (D9J). They're hard-wired to the MOSFETs (Q2 & Q3). The diodes, MOSFETs and wires are glued down as a strain relief. 'Cuz clear goop would just be silly.
Sure are a lotta extra parts on that board compared to an OCD or Alpha Drive.
Robert, I can send it down if you want
Do you see a cut trace anywhere around where those germanium diodes connect to the SMD transistors?
EDIT: Nevermind, I think I see it in your second pic, right above C4.
Looks like he just added a germanium diode in series with each MOSFET clipper.
I believe you are correct. Although I didn't realize this was built on the V2, I thought the Ge version was older than that.
There are some German and Japanese 1N314’s that have a sing green band as well… these look more like one of those to me.?.?
They look a lot like the green band unizen 1n34a. I have some I can take a picture of later if it would help?
@Barry is this the limited edition candy Red germanium OCD from around 2 or 3 years ago?
I thought the germanium ocds only used one germanium diode with one of the mosfets but your pedal has one for each. Maybe that's the difference between the customer shop red one and the older units? The newer one is a V2 with a germanium diode on each mosfet
Mine is green
