Yes, fixed that, thanks. That got the LED working, got rid of the popping and got me sound. Sounds very scratchy and the rotary switch doesn't change anything. What should I check next?I may be wrong, but it looks like your DC jack is wired backwards. Is that possible?
Make sure you have the Oct 1 and Oct 2 controls turned up, the rotary won't have any effect without some of the octave blended in.
Once I fixed the polarity on the DC power I get sound. I am now trying to debug why the rotary switch isn't working.Check your Footswitch for Continuity to make sure you have no bridges between pins up & down.
You should not have any Continuity from left to right on middle pins:
Check to see if the Rotary centre pin is making contact with the main board.Once I fixed the polarity on the DC power I get sound. I am now trying to debug why the rotary switch isn't working.
I'm going to check all the solder connections tonight when I get home. Do you know how I can measure continuity of the center pin with a multimeter?Check to see if the Rotary centre pin is making contact with the main board.
If you have a digital multimeter it likely has a continuity tester setting. Otherwise you can rig one up with an LED, a resistor, and a coin cell batteryI'm going to check all the solder connections tonight when I get home. Do you know how I can measure continuity of the center pin with a multimeter?
Thanks. I was trying to figure out which pins to check continuity between. I understand the pins outside the circle are the selection, but I'm not sure what the center pin doesn't and how they correlate to the header pin that connects it to the main board.If you have a digital multimeter it likely has a continuity tester setting. Otherwise you can rig one up with an LED, a resistor, and a coin cell battery
It will connect to 1 of the 10 inline pins , the other 9 being the outer PinsThanks. I was trying to figure out which pins to check continuity between. I understand the pins outside the circle are the selection, but I'm not sure what the center pin doesn't and how they correlate to the header pin that connects it to the main board.
Awesome, thanks. Yes I know how to use DMM in continuity mode.It will connect to 1 of the 10 inline pins , the other 9 being the outer Pins
Do you know how the DMM Continuity works?
Cool, Check the centre Pin for Continuity to to the matching pin on the Adapter board then from the matching pin adapter board to the main board & repeat the process for the other 9.Awesome, thanks. Yes I know how to use DMM in continuity mode.
Thanks, I will try this out tonight. Hopefully this will show where the problem is.Cool, Check the centre Pin for Continuity to to the matching pin on the Adapter board then from the matching pin adapter board to the main board & repeat the process for the other 9.
Go to your 1st message & click on Edit & in the header it will give you an option on the left to mark it as SOLVED.Okay I got it working! I went through and re-seated all the IC's in their sockets, and sure enough it worked for me. Thank you everyone for helping, and putting up with my noob mistakes.
