MichaelW
- Build Rating
- 5.00 star(s)
This is technically yesterdays build, and lest anyone think I did nothing but build pedals Friday while I was supposed to be working....well I did to some work.....I had a few meetings....
Actually had this one built earlier in the week and just waiting for some components (more on that later).
This one was totally off the radar for me, I had no idea it existed and only vaguely aware of the name Schnobels, and I though it was a Youtube pedal reviewer.
(Actually I think there IS a YouTuber with that name the does pedal reviews....)
Anyway, it was a total surprise when @Robert threw this in with my Tellurian Drive order. He said "since you like low gain drives, I thought you should try this one....)
So totally stoked it got bumped to the top of the list. So this is the first vertical oriented 1590BB I've ever built (The second one was my AquaBaby).
This is a BIG honking board and it's got a lot of components. This is one of the few boards I've build where there capacitors out number the resistors. And FIVE Opamps.....
It's also got some really goofy compnents......like a 576k resistor. Or a 12.4k. I wound up hacking those two with a pair of 1/8watts teepee style.
It also calls for a 12v Zener, a 5,1v Zener and 4x 2.5v Zeners....I'm like "wtf? what does this actually run at??" (the answer is 5v.)
Since there's no schematic for this build I had to take a bit of a guess at that does what by looking at the traces on the board. It uses Zeners for clipping, and the 2.5v choice is an odd one. Of course 2.5v Zener is the one value I did not have. I had some 3v's but I checked with @Robert and he said it would change the clipping threshold. Sigh...so I even though I have a bunch of 1 watt Zeners I went ahead and ordered a "kit" of 1/2 watt Zeners off Amazon with 50 values.
Then I found some cheap 2.5v Zeners on Ebay and got some of those. So if anyone needs 2.5v Zeners, hit me up.
When the Amazon man arrived yesterday afternoon with my Zeners. I was just buttoning up and testing my AquaBaby, so instead of cleaning up my work area, figured I'd finish this pedal as well. Only one problem, the kit contained 2.2v Zeners, 2.4v, then jumps to 2.7v. I was STILL missing the blasted 2.5v.
Robert said 2.4 was probably close enough. But I decided to socket them and swap them out when the rest of my 2.5's arrive.
I haven't played with it much yet but I do like what I'm hearing. It's a low gain drive that sounds really good when it's turned up. I don't know what the toggles do yet so gonna read up on that today. Very cool pedal!
This is also another rattle can color I'm trying, it's a textured finish. I still managed to get some scuff marks on it though, but I'm getting there! I love the color.
Also this was a re-purposed empty enclosure. I've been experimenting with different epoxies to plug holes and re-use some of my borked enclosures.
The inside looked like a mess after I finished plugging the holes with JB Weld. So I sanded it down and painted it with some cavity shielding paint so it looks a little neater.
I do have one issue with the build that I have not tracked down yet. The status LED won't come on. The pedal is engaged and also bypasses but the LED stays dark.
I've already confirmed its not the LED (swapped that) and its not the polarity (tried it both ways) and it's not the CLR, that measures fine at 4k7.
More troubleshooting later.
Anyway, very cool drive pedal for the low gain thing!
Oh, also, not completely decided if I like the 4 big knobs or the 2x2 knobs arrangement. Thoughts?
