Something new, or retired?I started on a Madbean Dreamtime today. It's an fv-1 delay and reverb in a 1590a with stacked boards
Retired. I'm still working on stuff I planned on 2019Something new, or retired?
RelatableRetired. I'm still working on stuff I planned on 2019![]()
You had me until 1590aI started on a Madbean Dreamtime today. It's an fv-1 delay and reverb in a 1590a with stacked boards
Truth.It's hard being an ideas guy
I was just gonna put it in a 125b until I realized it was stacked boards and I just have to do it for the challenge. 4 pots too, so making graphics is gonna be really stupidYou had me until 1590a
Especially a broke ideas guy, and a perfectionistic ideas guy who keeps putting off execution in favor of more intense planningIt's hard being an ideas guy
The great thing about 1590a builds is they fit in 1590B with room for top jacks and mods.You had me until 1590a
I'm with you but I speak and spell American English so "meter" is the only option for me. I do have to teach both spellings in my day job as an English teacher.I'm on board for making things make sense, and the metric 10-base does a pretty good job of it:
10mm=1cm, 10cm=1dm, 10dm=1m, 10m=1dam (dekametre), 10dam=1hm (hectometre), 10hm=1km
Makes sense to my mathematically-challenged mind.
Latin prefixes for units smaller than a metre:
Deci- means 10; 10 decimetres make a metre.
Centi- means 100; 100 centimetres make a metre.
Milli- means 1,000; 1,000 millimetres make a metre.
Greek prefixes for units larger than a metre:
Deka- means 10; a dekametre is 10 metres.
Hecto- means 100; a hectometre is 100 metres.
Kilo- means 1,000; a kilometre is 1,000 metres.
Alas for homebrewtj, in the construction industry the imperial system is well-entrenched. Canada has been metric since... 1976? *Internet search* ...
No, 1975 on April Fool's day(a dubious day to start IMO), Canadian weather reports were given in Celsius.
At -40º, it doesn't matter whether it's measured in Fahrenheit or Celsius.
Anyway, metric's been in use in Canada for nearly a half-century and the construction industry still uses "board-feet" of "2x4"s for studs that are 16" apart... etc.
I'm avictimsurvivor of that changeover and while I prefer Celsius now I still prefer 0-60mph,
quarter-mile times
, and MPG
— I guess 0-100km/h isn't too bad, I can wrap my brain around that, but... 1/4-km times is nuts as is LITRES/KM
; but travel-distances in km are okay, too. After 5 decades, my brain is still stuck between the two systems.
The US,
LibyaLiberiaand Myanmar
are the only holdouts for imperial measurements, and even then the US throws a
curveball with its own version of gallons, where a US-gallon
is about 20% smaller than an imperial gallon
, and other otherwise-imperial units such as tonnage
(imperial-ton 2,240 lbs vs US-ton 2,000 lbs) etc...
Niggling details:
— A "meter" is a device used to measure something.
— A "metre" is a unit of measurement.
Let's not even talk about "daylight saving time
Possibly the coolest post on this whole forumMy Amp-Sifu friend’s busy work bench…
The Reverb Deluxe clone built by another friend (another apprentice of Amp-Sifu), using a non-Fender vintage transformer. So it’s wired differently and was blowing fuses. After figuring out the transformer wiring with Sifu’s help, it is working and super-clean but to the point of brittle/harshness — more fine tuning to be done.
Sifu is too busy with amps to repair the stack of wahs building up.
So I’ve been tasked with sussing this one out, another luthier-friend’s. Visual inspection good, continuity good… haven’t had a chance to plug it in…
Yet another friend’s project. I built an on-board boost for it.
Switch was a push-button affair w/ LED ring. To make it work we wired up a relay, but the relay alone drew 2mA. So ditched the relay and switch, a simple toggle was dug out of a drawer…
And then there are all the amps in for repair…
A fraction of what’s on hand.
The Tele-builder’s Blues Jr, power-transformer is dying.
A Soldano Pre, Carvin V3, the usual assortment of Marshalls and Blues Jrs and then this wild card:
You guys just don’t even know……Relatable
I’m still not started on some stuff I planned on for 2014
