You're not alone, I made that mistake twice last week, with etching...I just realized the trims are labelled backward![]()
Dang, I do not envy youYou're not alone, I made that mistake twice last week, with etching...
How do you make that pitch variation? Are you using a whammy bar or is it a vibrato pedal?Made the trimpots external, used 9203 LDRs and an ultrabright diffused red LED. Replaced all the 6.8n caps in the phase stages with 10n.
Even without the little tweaks, this is still the best phaser circuit I've used. Highly recommend
It's just me bending or applying vibrato to a single string. Just a thing I developed to make my power chord riffing a bit more variedHow do you make that pitch variation? Are you using a whammy bar or is it a vibrato pedal?
Anyway the pedal sounds great. Some Zappa tones in there. I'm excited for when I finally finish my Duo Phase. Two Phase IIs must be better than one!
Nah, keep your technique secret hahaIt's just me bending or applying vibrato to a single string. Just a thing I developed to make my power chord riffing a bit more varied
I can try to make vid demonstrating it a little later if you'd like
Also, the DuoPhase is indeed twice as nice
I'll snap some in a bit when the coffee kicks inWhy no gut shots on any of these? That's the only part that matters.
Lemme wake up a bit, and I'll do a tasteful hand modeling gig for y'all.Nah, keep your technique secret haha
Kidding, it'd be cool to see.
I realized that I always bend or pull single notes a little bit to keep them moving but I don't do it with chords because I play 11s. My new Epiphone with 10s on a Gibson scale might change this though
So, here's a quick show of how I add a sense of melody to my caveman riffing.Nah, keep your technique secret haha
Interesting! The guitar too!So, here's a quick show of how I add a sense of melody to my caveman riffing.
I use drop tunings, in this case Drop A. I have the basic, groovy root+fifth, then to fill up some more sonic space, I'll double that up with an octave of the root+fifth. I usually apply the wiggly bits to the higher pitched fifth, though I do employ other intervals at times. Far from jazz chords, but it works for my screwed up nerves
Wow, so many unique features. Is that a white poly neck?Yeah, not terribly exciting. But, it works for me.
The guitar is a Meteora baritone a mate and I whipped up last year - View attachment 42812
Yep! I always wanted a white-out guitar (that wasn't a shreddy Ibanez), and this seemed the perfect build to apply that toWow, so many unique features. Is that a white poly neck?
