Magnetron (DMD2 actually)
The jack only has 3 pins, it's a mono, only did a visual inspection and the, what in the picture says Tip switched, looked like the tip, will try to connect to the tip later when I get home.
To +1 everyone else, I'm pretty sure you have the I/O wires on the wrong lugs of the jacks. You can see all of the variants of these on the datasheet: https://www.taydaelectronics.com/datasheets/files/A-1121.pdf
The different versions add more lugs, but the location of a given lug never changes.
