Alan W
When I was building my amp, I planned on getting a pair of the Fender side legs to allow tilting, but then ran into a picture that showed a pair of slip on legs, and decided to give it a try. These work really well. I have an stl file I made for them, but they need to have the geometry done based on the dimensions from whatever amp they fit into. Assuming your amp has interior vertical strips that are set back from the rear edges, and that you have a ply panel that is attached to them—the dimensions you need are the set back of the vertical strip and how thick the panel is. The legs are 1/2 inch diameter aluminum, with slip on rubber ends. Super easy to print; to machine them would be tricky without a mill, or solid experience doing precision work on a table saw.
Getting your amp's sound away from the floor is a major improvement, especially if you are not playing on a stage.
