What’s on *YOUR* workbench?
This damn Fuzzrite doesn't wanna work. When I turn up Depth to bring in the second transistor the tone changes but the volume drops. Does that mean there's some signal shorting to ground or did I fry the transistor? Or is it because I wired the filter cap backwards?
More issues. I was following the drill pattern from the build docs. All my hand drilled holes are spot on except for the LEDs. Please advise.
You’ve got the face plate, so you’ve got more wiggle room than you would otherwise. How’re you planning to mount the LEDs? I’d suggest reaming them out/over-drilling and have the plate cover the excess.
This
This is designed for 3 or 5mm bezels like this that have a nut & washer to hold it in place.
You just need a round file to centralize the hole & slowly increase the drill size to get it fully central to the correct size hole.
I just pull the Led out on the ones available in Australia & snip of the excess tin back to the thread.
I believe you can buy just the bezel so you can just drop the LED in & out like the one I modded.?
This
The transparent lens bezels fit. I made a few small holes around and then enlarged them into one hole and now the bezels fit.
Thanks.
