I like the trace routing treeA little preview of my in progress project. An old soldering iron sure does come in handy. I took 20 min playing around with woodburning last night and am sketching out some ideas/practice today.
I'd appreciate some feedback on the labels I used on the switches, before I have another batch made with perhaps questionable control names (I'm not a native English speaker). The yellow toggle switches between standard Chorus and Chorus with the modulation (LFO) turned off (it then just adds a short delay between L and R). This is a feature inspired by the Rockman Soloist. I think they called it Doubler, which to me is ambiguous (is it a double chorus? What exactly does it double?). Others call this effect Double Tracker. Too long won't fit (TL; WF). Stereofy maybe? I just labelled it NO MOD, for no modulation. Does it make sense, or is it too obscure/not the best word choice? How about LFO OFF or NO LFO? Do you have any preferences here?@JTEX bummer x10!
*Very interesting project though- I'll be looking forward to seeing the next batch with a gut shot![]()
Here's the gut shot. Won't change with next enclosure batch.
So, I done did the shit- color cycling LEDs in the Pendulum. I also tried the flickering flame LEDs, but they're kinda meh
Here's a couple demos before I box it up. Only mods beyond the LEDs are a 324 for the LFO, GL5528 LDRs, and a C250k speed pot
A Mini-mega'd Multiwave
Hoping to get this, the Corruptor above and a third circuit boxes and demoed today
The color changing LEDs are cool, but too unreliable and noisy in a way I find displeasing.
I'll have to give that a try. I did strap a 10u across each LED, and it helped, but it messed with the cool bits a lil too muchFWIW, I've been successfully using color-cycling LEDs as bypass indicators and under transparent-shafted pots with transparent knob without any noise. I just ensured the LED and its CLR are fed power directly from the DC jack with a 100nF and a 1nF cap in parallel.
Yeah, just want to damp that µPU noise down a bit. 10µF is a bit aggressing for that super tiny µPU.I'll have to give that a try. I did strap a 10u across each LED, and it helped, but it messed with the cool bits a lil too much
FWIW I would personally go with "LFO OFF" and "NO FB".I'd appreciate some feedback on the labels I used on the switches, before I have another batch made with perhaps questionable control names (I'm not a native English speaker). The yellow toggle switches between standard Chorus and Chorus with the modulation (LFO) turned off (it then just adds a short delay between L and R). This is a feature inspired by the Rockman Soloist. I think they called it Doubler, which to me is ambiguous (is it a double chorus? What exactly does it double?). Others call this effect Double Tracker. Too long won't fit (TL; WF). Stereofy maybe? I just labelled it NO MOD, for no modulation. Does it make sense, or is it too obscure/not the best word choice? How about LFO OFF or NO LFO? Do you have any preferences here?
Same goes for the delay toggle (NORM/NO FB). NO FB is no feedback - just a single repeat. Should I have called it Single instead? Then I can imagine the confusion if I use Doubler for the chorus and Single for the 1-repeat delay... How about 1 RPT? ONCE?
Am I overthinking it? Is it maybe OK the way it is?
Damn choices!
Exqueeze me, that's not an enormous 125B. It's a 1590B! I liked the challenge of trying to fit all that stuff into as small a box as possible, while still having space for a battery. In hindsight, that was pretty crazy, and it's definitely not a DIY-friendly design. But we have @Robert here, who I'm hoping to charm into making a DIY-friendly motherboard for a more reasonably-sized enclosure, using standard pedal parts, such as regular stomp switches and pots, through-hole passives etc. I'd much rather not make complete pedals, and focus on just the "brain" that people could plug into whatever form factor they prefer.[...] and very small feet needed to operate the 3-footswitches in the 125B..
Thanks, much appreciated. I also considered LFO OFF (or NO LFO for consistency with NO FB), but felt that mentioning the LFO might be a bit too technical. Your feedback might just sway me in the LFO direction.FWIW I would personally go with "LFO OFF" and "NO FB".
"NO FB" should be pretty simple to understand for people who have used a delay before.
All that AND room for a battery? Should've called it the tardis... and I don't even watch Dr. Who.View attachment 49151
Wow, that's a snug fit!View attachment 49204
I had to devise some super low profile stomp switches to be able to do that. The battery sits right below them.
P.S. I really wish Tayda would offer mix-and-match colors. I dig the blue bottom with the white top.
