DeadAirMD
I'm building the Equilux Mini and it calls for a component that is next to impossible to find, unless you sub in a LND250K1. Robert says that the SOT23 adapter boards here don't work with the LND250K1. Can I use a SOT23-3 board, or is that the same issue? Can I also solder the SMD to an adapter board and run wires to the appropriate pads?
