BuddytheReow
Moderator
I would be interested. I can shift gears and work on the body with all the fun filled sanding I have to domaybe I should do an "Fret Leveling A-to-Z" tutorial?
Would there be any interest in that?
Don't I need strings on it to even out the tension on the truss rod?Adjust the truss rod until you get the neck as straight as possible then check if the frets are level.
Here is some nice Bending on a Duesenberg, He has a vast video library of different lap steel playing!One big thing I’ve learned is that I don’t need fancy pants Fender necks to make a good build. From what I’ve experienced firsthand, I’d be perfectly happy with a Vintera Road Worn neck at a fraction of the cost of the American Originals. Not only did they cost a fortune, the amount of work they needed was embarrassing (for Fender)! I expected nut work, but one of them needed a majority of the frets to be re-glued. On a neck that cost as much as a whole-ass MIM Player series guitar.
I would love to build a Troublemaker Tele with Gibson appointments and P90s. After that, I’d love to build a Tele with a Certano Bender for B and G, like this one (not mine):
Nope not at this stage.Don't I need strings on it to even out the tension on the truss rod?
How often would this need to be done from a maintenance standpoint? I figure if I'm going to do this on one I may as well try it on my other more used onesNope not at this stage.
Really only as needed. the primary fret level basically sets you up until you need a fret re-level. For some folks that can be never, for instance. I play with a pretty light touch and have never had to "re-level" my frets even on my oldest guitar (35 years.)How often would this need to be done from a maintenance standpoint? I figure if I'm going to do this on one I may as well try it on my other more used ones
Sorry for the derail but… Wow. This is a picture from last year of my 1977 Strat (I got it used in 1985) before I finally had to replace the frets (I went with stainless just in case I happen to live to be 125 years old. You never know). Apparently I really like playing on the high E stringReally only as needed. the primary fret level basically sets you up until you need a fret re-level. For some folks that can be never, for instance. I play with a pretty light touch and have never had to "re-level" my frets even on my oldest guitar (35 years.)
Plum crazy purple(Besides Gremlins, how many purple cars do you remember?
Wait. Are you saying purple is a bad choice?I just looked up the lightfastness on the Mixol violet, and it’s pretty remarkable, as in general, purple tints and dyes tend to be the most affected by UV. (Besides Gremlins, how many purple cars do you remember? This is due more to color chemistry than good taste…) Mixol rates it for outdoor use, with 2500 hours of sun exposure, which is their second highest rating.
Pawlonia and basswood are different species of treeI built a GFS kit back in 2013. I shaped the headstock with some rasps in a shape inspired by G&L. I finished the body (pawlonia? I think it’s just a fancy name for basswood) with linseed based pigment and linseed oil and I was pretty happy with it. It’s a very thin and delicate finish but it looks nice, kinda like a thinner nitro. I did mess up the position of the bridge a bit (too close to the pickguard) so the intonation is crappy. I do like the maple neck though, not bad at all and the action is nice and low.
Here’s a pic of the body in progress:
And my face that says “I can’t believe it’s a guitar that I built!”:
(I was rocking a mustache back then)
Ok I never figured that out. It’s a pretty soft wood. And extremely lightweight!Pawlonia and basswood are different species of tree
This was a 30" scale Explorer type I had Pitbull Guitars in Australia kit up for me. Loaded it with GFS gold foil P90s, and went for a kinda vintage Japanese look as far as aesthetics go
