I have try only with water, no precise mixture, i added as salt as the video (a little less)Really cool! Is there a certain mixture of salt and vinegar that you need to use?
Thanks. I'm going to try that! Do you think it would work on a powder coated enclosure?I have try only with water, no precise mixture, i added as salt as the video (a little less)
that would probably not work since the paint is an insulator from electric current. you could take a powder coated enclosure and sand most of the paint off of the top of it if you wanted to give it a try.Thanks. I'm going to try that! Do you think it would work on a powder coated enclosure?
Did you only use a single 9V, from the pic that's what it looked like. The youtube demo had 2 in series. I wonder what the difference would be, maybe faster etching?Hello everyone,
I just tested this. It's a simple method to etching with 9V battery and salt water (or vinegar)
I use a paint marker (oil based see pic) to do that. Here my test and i do it on my tube screamer.
View attachment 3994View attachment 3995View attachment 3996View attachment 3997View attachment 3998View attachment 3999View attachment 4000View attachment 4001View attachment 4002View attachment 4003
Hope it will serve you
