drgonzo1969
hahaha every rabbit hole has a price it seems
Seems like a TL022 fixed it for some. Moving wires away from the LFO fixed it for others.Just finished a Duo-phase but it has a very audible clicking noise. Well maybe not very but loud enough for me. So I’m gonna try a few things. I also need to make a faceplate for it before I make a build report.
Moving the wires or using shielded wire has worked on all the ones that I've built.Seems like a TL022 fixed it for some. Moving wires away from the LFO fixed it for others.
I didn't know font managers were a thing until you just mentioned it now. I have probably over 1000 fonts on my laptop, and scrolling thru them to find one in the style I want when I dont know the name can take literally over an hour or two. Good to know for sure!Oh dear. Write back when your operating system startup begins lagging because you have so many fonts and haven't switched to a manager yet.
Is there a certain position where the TL022 might help or is it all of the 072 to replace? Any idea @jimilee, I haven't heard of this before, only heard of it in connection with the XC phase (fixed that for me). Cheers!Seems like a TL022 fixed it for some. Moving wires away from the LFO fixed it for others.
I wonder if you might have better luck printing on textured surfaces by first doing a flood coat of some sort of transparent epoxy to give a smooth raised surface where the print can sit. Generally screen printing isn’t done on textured surfaces since it’s so difficult though— I know even heavily textured papers are advised against for serigraphic prints.Printing on textured surfaces is a nightmare...unfortunately i have a bunch of this powder still....Im thinking of just finishing out one or two more so as to not waste it but after that im staying away from textured powder coats in the future for sure...Im hoping once the hardware is all on it will come together a little better.
That would be an amazing idea! Ive been looking into different inks and i think a 2 part epoxy ink called Nazdar ADE is what would probably benefit on this type of surface. Im pretty sure they even have a clear coat like epoxy. Regardless im staying away from textured surfaces after i run out of this batch, heck i might not even do anymore prints on textured surfaces from here on out. Just leave them un labeled for the time being....I wonder if you might have better luck printing on textured surfaces by first doing a flood coat of some sort of transparent epoxy to give a smooth raised surface where the print can sit. Generally screen printing isn’t done on textured surfaces since it’s so difficult though— I know even heavily textured papers are advised against for serigraphic prints.
A clear powder would work too right?That would be an amazing idea! Ive been looking into different inks and i think a 2 part epoxy ink called Nazdar ADE is what would probably benefit on this type of surface. Im pretty sure they even have a clear coat like epoxy. Regardless im staying away from textured surfaces after i run out of this batch, heck i might not even do anymore prints on textured surfaces from here on out. Just leave them un labeled for the time being....
I actually haven't thought about that. I'm guessing you're thinking of doing a clear coat over the enclosure therefore giving it a smooth surface? That might actually work. I only have so much powder left over I'm thinking i might leave one enclosure alone and give that a try for future references.A clear powder would work too right?
Yeah, clear powder can also be used to create some depth with the screening on top. Since you've already got the setup, it'll be easier to integrate clear powder into your workflow than using an epoxy, and you don't have to be as concerned with chemical compatibility or risk of yellowing (which can be an issue with some epoxies).I actually haven't thought about that. I'm guessing you're thinking of doing a clear coat over the enclosure therefore giving it a smooth surface? That might actually work. I only have so much powder left over I'm thinking i might leave one enclosure alone and give that a try for future references.
Man your speaking all the sense in the world!Yeah, clear powder can also be used to create some depth with the screening on top. Since you've already got the setup, it'll be easier to integrate clear powder into your workflow than using an epoxy, and you don't have to be as concerned with chemical compatibility or risk of yellowing (which can be an issue with some epoxies).
Looks fucking great! I love the folded enclosures!Printing on textured surfaces is a nightmare...unfortunately i have a bunch of this powder still....Im thinking of just finishing out one or two more so as to not waste it but after that im staying away from textured powder coats in the future for sure...Im hoping once the hardware is all on it will come together a little better.
Thank you man! I hope to only get better at them! I want to start designing another style but i would like to wait until i get a box brake, that way i can make folds that are otherwise kind of impossible to get!Looks fucking great! I love the folded enclosures!
