y2kornfreak
not sure how to phrase this, but my leprechaun rainbow machine pedal works just fine without the backing screwed but when I screw everything in, I get a dry signal and a high squealing sound. Took the backing out and tried messing around with switches and pots and noticed it did it again when the 3PDT switch for the bypass is pressed all the way to the case. I figured it might be a grounding issue, but I’m using a regular breakout board and all the wires are in their right place. Am I doing something wrong or missing something?
