I use the same method: tape the whole thing up, hole punch, pilot hole with my smallest bit, then I go up one or two sizes, then step bit. I don’t usually get shavings under the tape, at least not substantially if I do. Are you using titanium bits? I found that those are necessary.@Fizz
Maybe tape up the enclosure but leave enough tape-gap around the holes to be drilled so the bit isn't grabbing at any tape;
that way you protect the overall finish, and if you do get some chips scratches close to the hole, it still won't matter because knobs...
I don't even know what to do with this informationeven though it was _strongly_ requested
I started labelling controls on my builds to be kinder to @Harry KlipptonI don't even know what to do with this information![]()
...and a huge 'blip' just appeared on my radar in the form of an optical compressor...
I'll be a guinea pig for youNew design. I will be making L brackets and rivet them at certain points so i can mount walls.
I designed it around a 1590DD sized enclosure...
How about a Je T'aime? (Lovepedal JTM). It's also a wee little board but sweet and bodacious drive sounds out of it.On the search for a tiny circuit to fill a little gap in my rack:
Just tested the El Sol :
What a nasty device!
It won't be a main-stay in my current set-up because I already use the Acid Rain which is more versatile, but El Sol could be super valuable in a more minimalistic rig. I'll be glad to add it to the SCHMORG reserve once I cut a real faceplate.
Ill gladly make yours! This one is a prototype....Im going to see how many I can get away with!I'll be a guinea pig for you![]()
What are these going on?
So metal....
